Oh No! Oil pump pickup tube hitting rod bolt. #100086
08/05/08 07:57 AM
08/05/08 07:57 AM
Tennessee
HOOVER24K Offline OP
super street
super street
Tennessee
I purchased a Kevko M-301 oil pan and was assured it would fit with my 4" stroke crank. Well, I went to put it on and 2 of the rod bolts hit. Its not much so is it OK to bend or dimple the tube to allow clearance or do I need a differant pickup tube?
Thanks, Marlin
I haven't contacted Kevko yet to see what they say, will be doing that today.
Re: Oh No! Oil pump pickup tube hitting rod bolt. [Re: HOOVER24K] #100087
08/05/08 09:59 AM
08/05/08 09:59 AM
God's Country Maryland
GODSCOUNTRY340 Online content
GODSCOUNTRY340  Online Content
Bend the tube for clearance.
Re: Oh No! Oil pump pickup tube hitting rod bolt. [Re: GODSCOUNTRY340] #100088
08/05/08 10:03 AM
08/05/08 10:03 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
What rods are you running?
Re: Oh No! Oil pump pickup tube hitting rod bolt. [Re: 69Cuda340S] #100089
08/05/08 10:22 AM
08/05/08 10:22 AM
uh oh, didnt you buy a kevco pan?
Re: Oh No! Oil pump pickup tube hitting rod bolt. #100090
08/05/08 11:34 AM
08/05/08 11:34 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Yes I did but I am running Scat i-beams with the cap screws. Should clear without a problem. My guess is the OP is running stock rods.
Re: Oh No! Oil pump pickup tube hitting rod bolt. [Re: GODSCOUNTRY340] #100091
08/05/08 12:15 PM
08/05/08 12:15 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: Oh No! Oil pump pickup tube hitting rod bolt. [Re: GODSCOUNTRY340] #100092
08/05/08 01:02 PM
08/05/08 01:02 PM
that would cut down on oil flow and plus, those tubes dont bend easy, do they?
Re: Oh No! Oil pump pickup tube hitting rod bolt. #100093
08/05/08 01:25 PM
08/05/08 01:25 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
Id use a different tube
When you bend it, you run the risk of reducing oil flow
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: Oh No! Oil pump pickup tube hitting rod bolt. [Re: 69Cuda340S] #100094
08/05/08 01:30 PM
08/05/08 01:30 PM
Tennessee
super street
super street
Tennessee
Scat H-beams. I have since called Kevko and they assured me it is supposed to clear so they are sending me another pickup. The tube attaches to one of the main cap bolts (as a support)so it is going to be difficult to bend as it is hitting close to the oil pump. The thickness of a nickel is about all I need.
Thanks for your help.
Re: Oh No! Oil pump pickup tube hitting rod bolt. [Re: HOOVER24K] #100095
08/05/08 01:33 PM
08/05/08 01:33 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Lots of guys run the Kevco oil pans and pick ups with 4" cranks. This is the first case I have heard that doesn't fit. Hopefully the next pickup will clear.
Re: Oh No! Oil pump pickup tube hitting rod bolt. [Re: HOOVER24K] #100096
08/05/08 01:42 PM
08/05/08 01:42 PM
is it screwed in correctly? maybe its angled wrong. also, if the oil pump isnt seated right, it could bind up?
are you running arp bolts or stock style main bolts? Arp bolts will hit the oil pump unless you grind the heck out of them (I ran a stock bolt in for the #5 main
Re: Oh No! Oil pump pickup tube hitting rod bolt. #100097
08/05/08 01:53 PM
08/05/08 01:53 PM
Tennessee
super street
super street
Tennessee
Stock bolts. I've taken it in and out several times with the same results (twisting and turning the tube in and out) just to make sure it wasn't me. I am using a windage tray main bolt with the bolt on top to attach the support on the tube.
