HHR fan #1000807
05/27/11 02:47 PM
05/27/11 02:47 PM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
I'm scavanging the salvage yards for a hhr fan, with no luck. Are there any other models that use the same fan assembly??
Re: HHR fan [Re: '84 D150 Shorty] #1000808
05/27/11 05:42 PM
05/27/11 05:42 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
- Stu Harmon
Re: HHR fan [Re: feets] #1000809
05/27/11 07:03 PM
05/27/11 07:03 PM
TN
Pickup Man
Pickup Man
TN
Well my main problem is the cost of the fan. I don't have the funds to shell out for one. I am currently using the Taurus FM with a SPAL PWM controller, but I can only use the low speed because of the massive draw this thing uses. The HHR fan uses less amps, moves more air, and is decently affordable. I would use the Mercedes fan if i could find one cheap enough...seems like the trigger wire setup on it would work with SPAL controller and it moves lots of air, maybe I get lucky and stumble over one in the pullapart...
Re: HHR fan [Re: '84 D150 Shorty] #1000810
05/28/11 08:25 AM
05/28/11 08:25 AM
tboomer Online work
tboomer  Online Work
Everything you need to know about an hhr fan here..
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: HHR fan [Re: tboomer] #1000811
05/28/11 10:16 AM
05/28/11 10:16 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
why waste your time with used?
new buy it now $46+$10 shipping
http://cgi.ebay.com/TYC-RADIATOR-CONDENS...=item19c5740454
perception is 90% of reality
Re: HHR fan [Re: Mr T2U] #1000812
05/28/11 10:17 AM
05/28/11 10:17 AM
tboomer Online work
tboomer  Online Work
Also check Rock Auto...
