Re: What is the pinion angle ?
[Re: Wedgeman]
#1000415
05/26/11 07:15 PM
05/26/11 07:15 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
4 DEGREES AUTOMATIC 6 DEGREES 4 SPEED ???
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: Wedgeman]
#1000421
05/26/11 11:57 PM
05/26/11 11:57 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Pinion snubber, caltrac, ladder bar or nothing? they all take something different.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: Evil Spirit]
#1000424
05/27/11 01:53 PM
05/27/11 01:53 PM
Posts: 5,080 organ
maximum entropy
organ
0° is the optimum operating angle under full acceleration, hence the 7° nose down pinion angle. 7° is the typical amount of rear axle housing rotation under full acceleration with ss springs. 0° between the output shaft of the transmission and the pinion. the output shaft angle plays an equal role in determining pinion angle. pinion angle can be adjusted using the output shaft as well as the differential housing. remember to have the suspension loaded as well. if the angle is set without considering output shaft angle, your actual pinion angle will likely be incorrect.
[Re: maximum entropy]
#1000425
05/27/11 02:23 PM
05/27/11 02:23 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
You can take the driveshaft, stick it in a hole and mount your mailbox on it for all it affects PINION ANGLE. Pinion angle is the angle of the centerline of the engine/trans compared to the centerline of the pinion. You want these centerlines parallel under power. About 1-2*'s of u-joint angle helps joint life. This has been beat to death before - the driveshaft doesn't even have to be in the car to check or set pinion angle.
Free advice and worth every penny... Factory trained Slinky rewinder.........
