Page 1 of 3 1 2 3
I need a Decent inexpensive 440 recipe #1000255
05/26/11 03:41 PM
05/26/11 03:41 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I need a decent inexpensive engine recipe For a 73 Roadrunner 3:55 rear gear 2000 stall I have a 77 MH block a cast crank 75 HP block and a 67 block. I also have 452 906 and 516 heads. I would like to make 400 hp at the rear wheels.
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000256
05/26/11 03:44 PM
05/26/11 03:44 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I would hope the 67 440 has 915 heads, if they do thats what i would use hands down, just open the exh valve to the 1.74 size.
Re: I need a Decent inexpensive 440 recipe [Re: ademon] #1000257
05/26/11 03:53 PM
05/26/11 03:53 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Sorry I forgot about those heads It does have the 915 heads. The 452" I have have already been checked and surfaced so I would prefer to use those.
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000258
05/26/11 04:53 PM
05/26/11 04:53 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
disregard...400hp at the rear wheels...it'll take more than I originally offered
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: I need a Decent inexpensive 440 recipe [Re: Prince_Valiant] #1000259
05/26/11 05:01 PM
05/26/11 05:01 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
Concentrate on the shortblock and the oiling system. Get some good pistons with a decent CD.
Re: I need a Decent inexpensive 440 recipe [Re: dOoC] #1000260
05/26/11 05:43 PM
05/26/11 05:43 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
73rrak,
Send me a PM. I can send you a couple good recipes with ET/MPH to back them up.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000261
05/26/11 06:03 PM
05/26/11 06:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Define inexpensive .
Re: I need a Decent inexpensive 440 recipe [Re: JohnRR] #1000262
05/26/11 06:10 PM
05/26/11 06:10 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
I think the question we're all wanting to know is how $$$ do you have to spend? I agree if wanting to make 400 rwhp I would use the 67 block. That engine will have more compression than a mid 70s MH engine right off the start plus if has the 516 heads they should offer more cc over the open chamber 452 castings.
Re: I need a Decent inexpensive 440 recipe [Re: OrangeProwler] #1000263
05/26/11 06:40 PM
05/26/11 06:40 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I would like to spend less that $2500 if possible. I'm not too worried about factory compression I'll be buying new pistons anyway I'm sure The block will need bored . The thin motor mount ears on the 67 block concern me (What does it take to break them ?)The 67 motor with the forged crank is probably my best choice other than the ear thing. What rods will the 67 motor have ( good ones or bad ones? )will the motor home rods be better?
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000264
05/26/11 06:45 PM
05/26/11 06:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
With this in mind use one of the later blocks , though the concerns you have about the 67 block are not really that big a deal and they awill all more than likely have LY rods which are not bad for your HP level wanted.
I would use the closed chamber heads though if they are 915's, but given your location I think you might be hard pressed to do it for that budget with new pistons and boring it.
Re: I need a Decent inexpensive 440 recipe [Re: JohnRR] #1000265
05/26/11 07:38 PM
05/26/11 07:38 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
The machine work will be done in Idaho I'll be dropping everything off at my uncles house when I drive through and pick it up the next time I drive through. It would cost me at least 10 times my goal price to have it done here the prices are higher and it would have to be done 5 times before it got done Correctly.... hahhahahh
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000266
05/26/11 09:33 PM
05/26/11 09:33 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
Sealed Power 6 Pack pistons, Mopar performance 292/.509 cam, Holley Street Dominator intake, 800-850 double pumper, 906 or 452 heads at least bowl ported with 2.14/1.81 valves. Tried and true recipe and as cheap as it gets
Re: I need a Decent inexpensive 440 recipe [Re: GTXX] #1000267
05/26/11 10:49 PM
05/26/11 10:49 PM
michigan woods
imfixinmopars426 Offline
michigan woods
440+6 pistons,.484 cam,perf rpm intake,750 v/s carb,home ported 906's,headers,11.95-12.05 et in street-3500#=cheap fun!
Re: I need a Decent inexpensive 440 recipe [Re: imfixinmopars426] #1000268
05/27/11 12:16 AM
05/27/11 12:16 AM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
1971 or 1972 Factory Stock Recipe. Period.
They run great on regular gas and they have power!
My 69,000 all original 71 383 Superbee runs like a bat out of (meatloaf)! Smokes the tires with ease. All stock drive train.
I have an 88,000 mile 440 from a 72 Imperial in my 84 crew cab dually with a cap and it smokes the tires with ease and runs great with its 4:10's and auto.
Mother Mopar already figured it all out if you want your ride to be low maintenance and fun.
All the money you pour into making it "fast" for the street is mostly realized when your fast car is beaten by the next guy.
Its about having a nice ride with some power for fun - not about having the fastest.
My says build something affordable that you can enjoy.
Cheers!
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: I need a Decent inexpensive 440 recipe [Re: WyleECoyote] #1000269
05/27/11 01:19 AM
05/27/11 01:19 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
This is what the machine shop thinks will work for me. Tell me what you think.
77 MH block (I already have it)
forged crank out of the 67 motor
forged pistons installed backwards to fit in the head pocket
9.7:1 compression
452 heads with heavier springs
Comp Cams XE285HL 21-228-4 http://www.compperformancegroupstores.co...WDGCAMhydFTxeHL
Torker 440 intake ( I already have it)
800 Holley DP carb ( I already have it)
and MSD 6AL Malory dist (that I already have)
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000270
05/27/11 04:30 AM
05/27/11 04:30 AM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Speedpro 2355 pistons on the 67's forged crank and the motorhome rods (probably stressed less) in your motorhome block .You'll need to rebalance your rotating assy. Your 452 heads and thin gaskets should give you about 9:1 CR for best use with pump gas (915's were prone to cracking and aren't designed for unleaded). Stock intake with a thermoquad (best). factory BB intakes actually flow quite well for 400hp so spend you money elsewhere. .060 wall chromemoly pushrods, HD Mopar performance stamped rockers, Lunati Voodoo 60301 cam kit with stock motorhome valve springs with rotators removed or 60302 cam kit with their springs. Good 3 bolt timing set. Valve guides cut for teflon seals.
I wouldn't use the torker intake and that comp cam for your heavy car cause it would be a dog below 2500 RPM ,cruising would suck.
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000271
05/27/11 09:18 AM
05/27/11 09:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Huh ??
The torker is the wrong intake choice , a dual plane is the better choice , sell or trade the torker for something suited for this build.
Re: I need a Decent inexpensive 440 recipe [Re: JohnRR] #1000272
05/27/11 09:52 AM
05/27/11 09:52 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Huh ??
The torker is the wrong intake choice , dual plane or a Holley street Dominator if you must have a single plane. .
, Another good choice would be an M1 single.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000273
05/27/11 10:03 AM
05/27/11 10:03 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
NAPA, AutoZone, Advance, et al, rebuilt. $1,600 with core...
Yous pays yer monies and takes yer choices.
Re: I need a Decent inexpensive 440 recipe [Re: Commando1] #1000274
05/27/11 11:32 AM
05/27/11 11:32 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
(915's were prone to cracking and aren't designed for unleaded) The 915 is by far the best BB head, by far!! and once you grind on the so called "unleaded heads" they are the same as any other head, you would need to use hardened seat inserts if you plan on driving a ton of miles, most weekend cruisers don't need the hardened seats.
Page 1 of 3 1 2 3
