Quote: I've used big (Jumbo) channellocks & I've used a wood clamp..
I've also used a small bottle jack if your working on the floor, put the jack under the bolt and push it a little then you should be able to get the nut started, I have a hoist and a pit jack to put pressure on the bolt
