Yep. Intake and the distributor are on the 440. You are saying the exhaust manifolds from the 383 will work and bolt to my exhaust system?
Dunno if you are planing on use the 440 exhaust manifolds but juts in case I would keep the 383 exhaust manifolds you actually have... the diff on years could make diff flange exhaust bolt holes indexing making don't match with your pipes flanges.
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
