So..... How would I go about explaining the deck height issue to the machine shop? Is there some sort of specs for deck height that I need to know about or will the machine shop have sufficient knowledge?
I am only going to bore the minimum I can because my stock block is only .006 tapered, the machine shop said I could put it back together and run it like that and it would be okay, I figured hell I got it apart already.....
Thankx, just a student trying to save a buck! flatblack68@gmail.com
