ok I understand, thanks. I think these may be a wise investment, I know there was a thread on this, but what do you think the stock caps can handle? considering my roadster only weighs approx. 1900 lbs. with 600 hp, it is pretty easy on parts, but if it is not worth spending $300 on that, I could put the cash to use somewhere else
I ran a stock cap 8 3/4 for a long time in my car 2400#
with me but I finally broke the caps... this was with
about 600hp and low 1.20s 60'... I changed to the alum
center after that... if I didnt go with the alum center
I would have gone with the good caps.... also a back
brace helps alot
