I know this is going to sound like a lot of work but pull the rockes of the right side, get a drill and a priming hex tool, start running the drill and then turn the crankshaft slowly. if the crankshaft goes around twice without oil coming out of the head you have an internal problem, if the oil comes out of the head at a decent rate then start checking the shafts and rockers.
