Im thinking of using 660 center squirter is this a good choice?
Yes
No...Because there is only one squirter per carb. Its really not enough fuel shot with that much plenum volume to get the car moving without stumbling a little. You would be far better off with a single plane and just a double pumper. The old school crap can work, but not like the modern annular carbs with all the jettable air bleeds and such. If you do it, you will wish later you had spent the few extra bucks for real carbs instead of buying them twice.
with all due respect, i can make the 660's work without a lot of hassle. but, i do prefer a set of 750's
