Thanks again Andy and Scott.
Here is the restoration of a 68 GTX four speed dash harness in some detail. This one was a double whammy. Beside the typical corroded terminals and cut off connectors, this also had some hidden meltdowns and also mice made dinner on some of it.
All factory internal splices are cleaned, re-crimped and re-soldered, heat shrink tubing applied and tape wrapped.
Here is the leftover carnage.
Tested end to end before wrapping.
