Quote: "figure out exactly where the pulsating vibration from the brakes is coming from"
Almost always a warped rotor or a hard spot.
Jacked it up yesterday and put a dial indicator on both rotors. Left rotor had .005 run out Right rotor had .014 and was all over the place. This is a wilwood kit with non-vented rotors. May have to use the vented units?
