Bad pump umbrellas can cause fuel to exit over boosters/vents when you stomp on it , could also be fuel pullover from squirters if check valves are missing/not seated , are bowl vents clear? , have sec jets had extentions fitted along with correct floats? , stuck floats? ................just some things to check.
