first off...this is the exact reason why i typically only work on my vehicles but this time i had no option as it was my daily driver and my clutch blew and i needed it fixed asap so i could drive to work.
chevy c2500 truck 4 speed should have been a no brainer, but the bozo somehow managed to crack my oil pan - presumably from how he supported it while removing the trans.
i put dye in it to confirm the leak its a tiny crack...do you think this can be JB welded?
i am going to go back tomorrow and see what they will do (if anything) but i am already bracing to fix this myself.
thanks
