All kidding aside those numbers are typical of a lot of BB A body ladder bar cars, go run it. the wheelie heights and distances will be determine by track conditions, tires, stall leaving the line and several other factors like front and rear shock adjustments and travel
Bob George had me set up my Ladderbars neutral !
With driver in place I have 846 RR and 852 LR with about 60 lbs. more on the LF than on the rF. 52& front and 48% Rear.
Our car also goes straight as an arrow even with some pretty good wheel stands set up this way with 60 fts, in the 1:31 range. BB B Body 3600 lbs. with driver!
Mike
