I have done the 64 to later axle conversion. The problem is that the housing is not machined to accept inner axle seals. You must run the green style bearing which does not require the inner seal. These bearings don't require the end play adjusters either. All you need are the correct length axles and green bearings. It's not a big deal.
Doug
