as a rough guess, i would say go for it. i'm thinking they should bolt up, but they are slightly different in looks. can you get the rear too ? you may have to drill or slot the frame mounting holes, or mix-n-match mounting brackets. i'm pretty sure the overall length & curvature will be pretty close. let us know how you make out.
