Quote: .I have a ton of spring on the car too.Idle time is what kills the springs.
How much is a "ton"? 200/600 or 300/800? How much valve lift are you running? When you say "idle time", do you mean time the engine runs at idle, or as in sitting idle for 3 months in the garage?
Like 250/700.Lift is in the 650 + 1.6 rockers.I mean idle time at a stop light with the oil hot as hell and idle at 1,000 RPMs.Kills the springs.
