I suggest you lock the dist out now for starters. Dont let people say it wont start, or cause a bunch of other problems starting it locked out...its total BS. 560CID + 16:1 compression, and stock Mini starter from a 91 Dodge Dakota. That engine wont need a bunch of timing either. Set it about 34-35 deg's and forget about it.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
