Quote: BTW, do I use the timed or full vacuume advance port for the vacuume advance on the distributer? (timed is passenger side) Just checking to see if it is hooked up rifgt. Currently the distributer is hooked to the timed port and I have the vacuume lines in the stock air cleaner hooked to the full vacuume port.
You have both correct
