It would be interesting to get some measurements of all the port areas. Since the head uses the same intake seat as their Ford 385(429-460) head, a bigger intake valve, throat and bowl work, with a shrunken exh. valve might prove interesting.
It sux that a good block to support 900-950 HP and live is $6k.
