[quote=IMGTX]I am not going to chisel this in stone but since nearly every front suspension part, radiators and stuff will swap on 66-72 b body and 70-74 e body it may open the search up a bit.
Before anyone calls out specifics, i know the parts changed alot over the years but they can be swapped. Including the k-frames even though the idler arms & sway bars are drastically different.
I don't see that part being any different on the early b bodies.
How wrong you are. 68-70 is longer than the 71-71 B-body brace. See pic below. WINGNUT
