In another tjought , It seems some use filters some dont , i use a screen . Would a deflecter across / in front of carb intake help , stop air straight over carb ? Or could it introduce further turbulence ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
