I would think the 68-70 Charger rear roof & rear window area would be needed to pull off the rebody. then add the quarters, door skins and front sheet metal. If the donor car was a 4 door body, you would also have to do a 4 door to 2 door conversion.
The question no one else will ask is: How do you think your going to get it titled as a Charger?
Some states only show the year, Dodge and Tudor for the body style.
