Looking for the engine and trans for my 1968 Hemi roadrunner.
RM21J8G119670
Block should have the following numbers 8G119670. This stamping is located at the back of the engine where the bellhousing would bolt into the block at the 12 o'clock position. Please note there is no machined pad like the 1969 and up engines, just the numbers on the rough cast surface.
The numbers 8G119670 also should be on the machined pad located on the transmission
Car was a Florida car all of it's life. Got it's hemi transplanted for a 383 early in it's life. The car was a 2 door coupe (pop out rear windows, post car) Bronze Metallic with a tan interior and an automatic on the column and a bench seat.
If you have any info on the original drivetrain please email me at:
domingo426@gmail.com
