Originally Posted by moparx
Originally Posted by EvilB1Dart
Originally Posted by Al_Alguire
Wes look into a mini split for the garage. I put one in mine two years ago and I can keep it as cold or as warm as I want all year long.
Al,
Never heard of one. Will check. However, I am having a 30'Wx30'Dx16'H shop built out back finally. It's as big as I can go, and will be plenty w/a 2-post lift also......and will have heat and A/C!!!!
what are the operating costs for a mini-split after the installation ?
beer
The are cheap to run. Ac works wonderful and heat is amazing when temps are above 40 but The problem you'll have if you live up north is that once it gets under 30 it costs a lot to heat and even with the best ones once it gets to zero can't heat. Just like heat pumps sub zero units have an electric heater strip to provide heat.
