I think I should get some type of oil containment system
It is a Street strip setup up with a Big Block in b body External oil pump and line to a pickup in the pan Engine lowered so it is close to the Center link
I believe I should modify the Center link to give clearance Anyone done this?
Oil tray or diaper?
Any pro and cons/advice???
Suggested suppliers?
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
