I say "most of" because the dash is still in the car which prevents me from completing the backside of the A pillar. I'm waiting until I get the left door off to pull the dash, so there will be less stuff in the way.
You can see what seems to be a rookie error, as I did epoxy a hard line into the surfacer because of the quick tape job, but I actually don't care and it is OK, its only sanded to 220 anyway. The hard line will disappear with another short pass of 220 blocking + the 320 and others coming after will refine it that much more.
Also decided on exterior color and did a couple sprayouts on the cut off door skin to make sure the color really is what it's supposed to be. First basecoat I tried missed the color pretty badly, second attempt just about nailed it.
