You want the sway bar horizontal at ride height - the sway bar ends swing on an arc that moves away from the LCA with travel, so if you start with the end links on an angle, the angle only increases (at least in one direct, would get better in the other), which reduces sway bar effectiveness and in the most extreme cases can bind.
