Originally Posted by AKcharger
I had the ENTIRE AC system refurbished...EVERYTHING. System runs fine, pressures about 30 PSI low side and 185 high side. after about 15 minutes f I drive it the clutch starts to lock up (belts NOT slipping) and pressures bounce around 85 Low side and 150 high side. has anyone seen this and have an idea what's wrong??
https://youtu.be/OwhaJn5edt8
When you've done all the checks and the clutch is still slipping; take the clutch off and show pics of the clutch face and the pulley face to see the wear on those parts.
