I've bonded a few vehicles in IL (the last one 2 years ago). I don't believe a bonded title would be required on this one. A good title agency makes things go much more smoothly.
There are even good Secretary of State offices that are helpful, as long as your not doing things like this a lot. Usually you have to talk with the right person at that office, and you need to have exactly what you need before the process can start. Its often easier to ask the right person at those good offices what you need to get the job done before you start the process, then come in later with everything the State requires.. With IL, there may be several forms needed, and matching dates on all the forms (within a specific time frame) are often required. You want to ask the person helping you what forms are needed, who has to fill them out, and what forms may need the same date on them. Bring in the correct forms, with the correct person having filled them out, with the correct dates on them. Pictures as well if needed.
Want a title? Jump through their hoops! Then be very friendly about it all with the person trying to help you. Its most likely not the person you are dealing with, but the stupid state that causes the problem. When it comes to titles, most of the stuff the state requires won't make much sense, but you have to do it their dumb way.
