Originally Posted by stumpy
What is the deal with the ends of the dutchman panel?
That's the way the "factory" finished off the ends of the Aero window plug and vinyl top trim with cast potmetal "triangles" to avoid bodywork, the vinyl top was also mandatory on Superbirds to cover the Aero plug's perimeter seam/welds, again to avoid costly/time consuming bodywork...
MikeG
