Originally Posted by Pacnorthcuda
Check the bulkhead connection on both cars. It’s a poor design that commonly fails on these cars as they age. The ignition power is fed though male and female spade fittings that corrode and get hot. Look for damage. Clean, and make sure they are making a tight connection.
My 69 Super Bee had that problem. When it would stall the first thing I did was unplug the bull head connector and plug it back in. It would start right up. I finally bypassed the connector and never had the problem again.
