I made up just the right length spacer to go between the TO bearing and the Transmission, put it together, got it running. But the clutch won't disengage cleanly enuff to put it in gear. So the trans needs to come back out and get that figured out. Also I messes up the threads for the fuel inlet in one of the carbs, it leaks a little so I need to fix that. But the motor seams to have no issues.
[img]http://i.imgur.com/boeexFms.jpg[/img] 31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
