It takes a lot of work to find big wheels and tires that fit, work and look good. A lot of work. Good luck with the process, it isn't easy.
I've always liked the Fikse wheels you used, Andy.
'63 Dodge 330 11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs. 10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
