Here's the problem. Reverse is slipping when you apply the throttle. It will pull itself from idle on the level on an incline it slips. Trans was rebuilt ,but now has about 40,000 miles on it. Quality parts used. There is no problem with the forward gears, firm shifts. Does this sound like a band adjustment? Fluid is full and bright red no smell. Thoughts/suggestions. A- 518 /46Re behind a 5.2.
America First!
