Thank for all the replies!
So, there's a lot to look into..
The backstory is I installed relays in my Alfa Romeo. It wasn't hard and it made a noticeable difference in light output and reduced heat build-up at the light switch - a very common weakness in the GTV6.
So, thinking the same for our Satellites, which are running four/two Wagner sealed-beam halogens. Then I wondered why not modern LED headlights.
The '67 has a glitchy hi-beam switch I need to troubleshoot, and I know the light output is a little dim because of the voltage drop across all that wiring, so I might as well upgrade while I'm sorting out the glitches.
Blinding oncoming traffic?.. why would that be a problem with LED headlights any more than conventional lights - the headlight buckets are fully adjustable up/down and side to side for the right lightcast! .. or do Mopar owners no longer know how to adjust headlight patterns? ...am I missing something?
I'll read through and check all your links again to educate myself more, see if I can map out an approach that makes sense for me.
I like the Jeep conversion on the Dart above, even if it's a little more work. I could try it on the '65, see how it looks with the modern reflector appearance..
I'd only install relays if I keep the sealed beam halogens.
- Art
