Gene, since buying the hemi I'm seeing problems with wiped cam lobes. Supposedly caused by lack of oil getting to cam area while engine runs at rpm's less than, say, 1700. I did notice when this engine was started it ticked for maybe 4 seconds before going away. Any thoughts?
Also, when you cut the frames, did you cut straight down thru frame, or cut down, over and then down again? Stepped it? Stepping it would make for a tough task to match it up......
Kevin
