I've read that these cars were prone to bump steer. With aftermarket tubular control arms etc it might be an idea if possible to track toe and camber change through its range of motion. If the geometry of the tubular arms is different than the stock ones, it might make a somewhat minor issue into something much more noticeable.
How good is the guy running the alignment machine? Lots of potential for error there too.
