I took mine out and examined it. No crack anywhere. I disassembled it and found it was leaking between the plastic body and the base. It has probably warped from the heat. I'll try using some fresh sealer on the mating surfaces. That heat shield is a good idea. I use headers, so probably not cooking it as much as an iron manifold. Those things hold so much heat.
