Something is not compatible. I would check with the company that made the wheels and find out what they recommend. My bets the outer diameter of the lug shank is to small for the wheel.
This was my thinking too. Seems to be some slop when you place a lug nut in one of the wheel holes. Was thinking of making some sleeves from thin wall steel tubing that would fit over the lug nut shank to take up some of the slop. But that's only a crazy idea of mine.
Has anyone else here had a issue with repo Cragar nuts?
