OK
So its a not a whole house unit right?
So how are you hooking up every thing? That you cant find a rubber 10/4 cord ? to run 30 amp as that's all the breaker on the unit will do?
Are you wanting to keep it out side all the time? Or are trying to cut the noise down when running it?
