Maybe related, I always wondered, if you paint an installed door in a closed position, does it want stick to together, and not want open when the paint is dry?
And the solution is?
I paint a few of the sections cracked open. Paint dries fast in.the heat here. Then dp.the rest.
As I am able to get Inside the sections whole open. It was white before and now a light tan..
I used a brush in the cracks and a small 6 inch roller on the sections it was good quality paint from Val Spar (PPG) Custom mixed to.matcj the vinyl siding on my home
