Anybody know what the roller wheel diameter is for comp 828-16 small block roller lifter?
If no one responds I can tell you tomorrow. Really disappointed in my last set after the tie bar broke in my sons 10.20-10.30 360 and destroyed the cam and engine. 60 runs on them.
Was that a non-removable link bar with a full rivit, or the removable type that you rotate verical to remove? Just curious as to which and if it was the removeable type, if that could have had anything to do with the breakage. Not that it should.
