1. Everything does not have a simple answer 2. Gravity appears to be simple, but few can precisely explain its true origin, its often just described only as a "natural phenomenon" 3. Not giving a simple answer when speaking to the masses considering the lowest common denominator viewer, should by itself not be a disqualifier 4. Requiring simple answers can be fraught with unintended consequences. 5. Fauci by most accounts is smarter and more knowledgeable then me, hard for me to judge him on infectious diseases.
He's suppose to be the expert on infectious diseases..and he may but if you start digging you will see he is in this for the money... start your own digging.. and try opening your eyes just a little
Like in "The Dr. Fauci Show" on Fox Network, coming soon to you.
