I give it a going over with 120. Wipe it down with acetone. Light coat of self etching primer. Use Krylon 5 ball paint. Depending on what it is, I may do it in sections. You have to be able to keep it all wet to avoid overspray and have it shine.
If the results don't match the theory, change the theory.
