Originally Posted by jcc
If requiring unlimited daily access to a grocery store in the beginning of a pandemic is the lack "oil" in your eyes, you might need to find another planet to inhabit.
And to answer your question then, no.
To panic people into food hoarding would be one of the worst possible actions that could be taken, if restrictions are required they need to be implemented VERY carefully.
Far better to take steps to bolster the food supply chain, if it falls apart we are screwed, glued, and welded.
IN red, stating the obvious.
Its not FOOD RATIONING that is the issue here, its too many people in one place not far enough apart to be safe, hence my spacing things out possible suggestions.
If people don't get that, and understand that, they will just peaked the curve higher, and mother nature will settle this problem.
Where did you get “FOOD RATIONING” (your caps) ??? We are talking about grocery store restrictions. Please stay on-topic.
