Originally Posted by gtx6970
Ive always refereed to them as spin weld bolts / studs.
they have a ring or series of raised dots or a ring on the bottom side of the head. The head requires a special fixture to spin the bolt and the ridge or dots weld themselves to the surface due to extreme heat
That's Projection Spot Welding. But there is a welding technique that spin welds.
