Originally Posted by 440whiteboy
Originally Posted by 71ragtop
Has anyone had success in repairing a crack in an E body door panel, if so any tips or advice, thanks
I used epoxy 2 part mix kit
Eastwood Company has many products -
type in the search box - plastic repair...
i am a autobody tech and repair plastic regularly. the panels are made out of polypropylene type plastic. repair of this plastic require use of adhesion promoter with a special epoxy. make sure you use the correct products for the repair.
if you use the wrong products it will only be a temporary repair.
perception is 90% of reality
