Hello to all my fellow mopar brethren!!
I am building a 1050 carb w/3 circuit metering blocks on 110 race fuel from scratch and I need some help with some baseline components. My specs are:
408ci SB in my 2900lbs Scamp on 28x10.5 radials with leafs and caltracs.
10.5 to 1 comp.
550 solid lift cam
Super victor intake w/2" super sucker spacer
904 w/trans brake
8" 5500 ptc converter
4.56 gears
I leave at 3100 and shift at 6400
I currently run a 750 double pumper on 110 race fuel with the following setup:
Jets
Front - 80
Rear - 78
50cc pump front and rear
.110 needle front and rear
Notched plastic floats front and rear set with fuel level half way up sight plug at 8.5psi.
The car has gone 6.68 @ 100.75 in the 1/8 with current carb but with a 9.5" 4500 ptc converter.
So what spec parts should I use for a baseline?
BP
